Mast step mount leak
chp
Sep 13, 2010
440
Hunter 280 hamilton
I seem to be having a slight drip coming down the outside of my compression post. I tried a search and all are to do with water coming through the wiring bundle which mine is not. The drain holes inside the mast step are clear. I suspect it might be seeping through the plate mounting screws. Before I try to remove these screws to reseal them, I was wondering if anyone knows if they are screws with a nut on the bottom or just large wood screws. There is no way to get at any nuts in between the deck and the inner liner. This is on a 1996 280.
Sep 24, 2018
4,644
Catalina 30 MKIII Chicago
Use BedIT butyl to seal it. Cheaper, better and longer life in this application than caulks. Even 4200 dries out after a decade or two
chp
Sep 13, 2010
440
Hunter 280 hamilton
Mine actually has a stainless steel tube welded to the SS base plate. No plastic. I originally thought water was getting in through that tube until I saw it was welded in. My thought is water is getting in through those screws. Might have to wait until winter when mast is unstepped .
chp
Sep 13, 2010
440
Hunter 280 hamilton
Thanks. I know the hole in the front of the plate. Never checked that one. I'll have a look.
