mast/spreader light use
barb
am i ever required by law to use my mast light and or spreader lights?
Jun 3, 2004
145
Catalina 27 Stockton CA
Yes and no
If by "mast light", you mean the white light on the front of the mast that shines forward, it is called a "steaming" light, and is required to be used at night on a sailboat when under power. You are not legally required to use a spreader (also known as deck) light, although they are a good safety item when you have to work teh foredck after dark.
Peter's right
I also recommend you purchase a book that includes all the rest of the rules of the road, you'll need it (we all did). Stu
Mar 25, 2005
25
Catalina 27 Atlanta
The Geeze factor
We do a bit of evening sailing on our local lake and I have had fishermen pull up beside me in their bass boats and tell me, "Your front light ain't right. That white light goes in the back!" It amazes me at times how many don't know the simple rules -- especially that of sail-v-power right of way!!! Do your research and be happy in the knowledge that you are safer than most. Especially knowing to ask questions instead of assuming the answers. Happy sailin' y'all!
don
lights
i purchased a laminated chart from west marine that gives rules for lights and other "rules of the road" good luck
