A simple $2 fix to those who step their mast and worry about the mast shroud/stay "T" fittings not seating right. Disastrous dismastings can take place either when raising a mast at the ramp or under sail when twisted fittings eventually (and unannounced) finally fail.A very simple 1/2" grey pvc 2 hole pipe strap from HD, pop riveted around the shroud/stay head about 1-2" down from the socket will keep your fittings safely and perfectly aligned. Works like a charm, took 5min and $2.50 but will never fail. Squeeze the strap to close it slightly. I only used one alum rivet on my H260 side stays(set slightly back from center on my B&R rig). With the mast set rearward, one lower rivet easily supports the stay and allows you to pull the the strap open to remove the stay fitting if needed. The forestay got two rivets(a little closer to the socket) that could be simply drilled out if you really needed to remove the whole jib assembly. Using pvc straps and alum rivets will ease any dissimilar metal concerns too.Good luck. Michael
