rad
I am about to start rewiring my mast. I figure there will be 2 wires plus an antenna. Of the 2 wires one will be a 3 conductor for the anchor/windex lights and the other a 5 conductor for the spreaders and motoring light. All told there will be 8 individual wires. I was thinking of using a 8 way trailer plug at the termination for easier mast removal at a later date. So there would be only an antenna plug and an 8 way trailer plug in the mast base. Does this sound correct. Also does anyone know of a replacement for the old metal mast wiring plug door. The old one is rusted and nows the time to replace it. I will also replace the antenna. I have heard the new cable should be RG-8X. Is this correct? And do I need to replace the antenna. It works well but its 20 plus years old. The mast base will have a Garhauer mast plate with 6 pulleys. This will eliminate 24 possible leak spots from the old degraded plastic pulleys bolt holes through the cabin top. I also would like the mount a solar panel plug at the mast base for the panel forward of the mast. Any ideas for a low profile weather proof plug?
