Mast rewire
Jun 21, 2022
23
Hunter Passage 42 Parkside Marina, Md
New owner of 93 Passage 42, the mast has been removed and I am planning on putting in a LED tri-color masthead light as well as an LED steaming light/deck light. looking for recommendations and should I also replace the wiring?
5,867
Oday 322 East Chicago, IN
While the mast is down, it is a great time to check all of the wiring as well as the shelves, rigging, lights and anything else at the top of the mast…VHF antenna and wiring, windex, wind anemometer, spreaders, deck lights, to name a few.
Nice boat…
Enjoy,
Greg
Apr 5, 2009
3,211
When I had my rig down for standing rigging replacement, I also replaced all of the old wires. I used Ancor 4-strand cable for both the top of mast and mid-height lights. With four strands at each location, I could attach up to 3 seperate circuits by using one for a common ground.
Jul 25, 2004
362
Hunter 42 currently in New Zealand
Just a word of warning on using LED masthead lights if you have a masthead VHF antenna (like most of us). Many of the LED lights will interfere with VHF reception if they are too close to the VHF antenna. OGM (Orca Green Marine) used to have this problem, although they may have fixed it. An easy way to check and avoid this problem is to take a handheld VHF and place it next to the LED light you are considering while the light is energized. (For example, if you are able to get to a chandlery that has the light on the sales floor, you can hook it up to one of their 12V starter batteries and place a handheld VHF next to it. If there's no static or interference, you're good). Good luck.
Ward H
Nov 7, 2011
3,814
www.marinebeam.com.
All of their LEDs have been tested and will not interfere with other electronics. Great tech support also. I bought a cabin light from them a couple of years ago. It arrived with the bulb shaken loose. I called them and the guy on the phone said yes, he installed the bulb himself and must of screwed it up. Sent me a new fixture and return label for the old one.
I've used their products for all of my cabin LED fixture upgrades and deck/mast LED fixture upgrades.
And yes, run new wiring while your doing the work. Will probably never have to worry about it again.
Sep 14, 2004
199
Hunter 42 Deltaville VA
www.marinebeam.com.
How did or do you get the wiring out of the mas?. I have roller furling and the channel for the wires is tight. And after 25 seasons the wires are stuck together and won't move.
BBC30... Is the mast down on the hard or standing on the boat?
Do you have lights on the spreaders? A mast mounted radar? Are you trying to get all the wires out or just one or two?
JamesG161
Feb 14, 2014
7,936
Hunter 430 Waveland, MS
Then test the old wires for Impedance and short circuits.
Inspect the wires, inside the cabin at the base of the mast. There should be an inspect plate cover.
Jim...
Jun 21, 2022
23
After mast was removed it was very evident the roller furler is bent/dented. lower spreaders broke off as well. Waiting on inspection so I have not attempted to remove anything. May end up just replacing
Apr 5, 2009
3,211
For me, when I had my mast down to do a complete replacement of the standing rigging, it was a no-brainer to replace all of the wiring in the mast. On my Catalina, this was made easier because the OEM wiring was typical automotive primary wire which has much thicker strands than does the Ancor wire and is not tinned. I liked using the 4-conductor cable for the additional protection from chafe.
Likes: Ward H
Jun 21, 2022
23
Sounds like frustration from the past owner, jammed mainsail.
Jim...
no the wind storm in April blew my boat off its jackstands! broken rudder, bent keel, bent stanchions, now bent roller furling ... the band keeps playing!
Likes: JamesG161
