I had a small issue lowering the mast. Had main sheet backwards when lowering mast and when the mast went over center the line was locked in the cam cleat. Need less to say mast kept going and gin pole stayed put and split the mast where the gin pole goes into mast.
Am wondering if ok to weld and fix or if anyone has suggestions other than replacing the whole mast.
Thanks
Thanks
