Sorry Alan, But you don't Understand
The quote provided by Gerry is as follows:"Although most people believe the wind blows straight along the surface of the earth, it does not. It blows slightly downwards at an angle of about 4 degrees. A mast which is leaning back 4 to 6 degrees will actually be presenting a leading edge which is at right angles, or very nearly so to the direction of flow of the wind."As a retired meteorologist, I realize that air is compressible and a fluid. It is physically impossible for the air to continue to flow into a given volume forever without air flowing out. That given volume is bound by a boundary between the top of the mast and the water surface. As defined by the author, this condition occurs everywhere. The author did not say that it occurred in localized areas or for short periods. By the way, the air, as defined by the author, is flowing down at a component which is .07 of the horizontal component (Tan 4 deg). Therefore with a 10 knot wind the air must be flowing downward at a rate of almost 0.7 knot. If it continued at that rate, I believe that within very few days all of the air in the atmosphere would be compressed within this very shallow layer. Talk about global warming, that would give you true global warming.Please explain what is happening to all of that air which is blowing down towards the water/ground, etc. Hey guys, this is fun.
