No. Prebend is to prevent the mast from inverting. If the mast is perfectly straight the middle can bend forward or aft. Prebend prevents this by inducing a slight bend in the mast so that the middle of the mast is bent forward.I was wondering why you brought up pre-bend then I seen it in his title. Pre-bend a sail trim component. Used for taking advantage of lower wind speeds not so much how the boat feels/handles?
You mention plural backstays - do you have a split backstay with a tensioner on it? If so, then they should be adjusted at rest without additional tension (or with 25% of the tensioner) so that the forestay has the tension needed for normal sailing conditions. Then the backstay tensioner is used dynamically to adjust the shape of the main as needed.I'm adjusting the backstays on the mast. I seem to be always guessing how tight to have them adjusted. Adjusting the backstay tension to where I thing it should be, the top of the mast appears to have too much aft bend in it. With the backstays too loose, I'm concerned my head sail furler may over bend and get a knick in the aluminum when wind gusts give it a snap. I use a Loos tool for the side shrouds, but the tension guide recommendation doesn't really make sense for the backstays.
It would take a very loose forestay to bend a furler extrusion. So loose that I'd expect the mast to jump off. Taking furlers on and off from a raised mast to dock usually involve it bending in large arcs with no issues, and they often get put on the ground where they take a large arc from the fitting up on the stands to ground.In the past I didn't have enough tension on the backstay and somehow, with a gusty conditions I presume, created a bend in the furler which I had to have repaired. I don't want a repeat of that issue.
Thanks DaveNo. Prebend is to prevent the mast from inverting. If the mast is perfectly straight the middle can bend forward or aft. Prebend prevents this by inducing a slight bend in the mast so that the middle of the mast is bent forward.
Rake induced both by tuning the rig and by the mast step. The mast step is not flat, it is either mounted at an angle or built with a slant on the base.
