My H25 mast has a huge rake aft because the roller furling headstay is too long. The backstay is tightened as far as it can go, and there is still so much slack in the headstay that when the wind is up I can't furl the sail because the furler binds. It must have at least a four inch catenary in it.I want to have a new headstay made when I return from Africa. How much rake is ideal for the H25? I have also noticed that there is about a 1" gap between the bow fitting and the deck. The bow itself and the bow fitting don't appear to have ever suffered any damage, and the strap that runs vertically down the front of the bow appears normal, i.e. the bolts are tight, and the bolt holes aren't elongated. Was there originally a 3/4" thick piece of teak bolted between the bow fitting and deck? Any idea if the bow fitting for a Catalina 25 will fit an H25? I have a brand new one with bow roller that I bought for my project Cat 25. An integral bow roller would be a nifty upgrade.
