Mike Clisby
I have a swing keel Oday 25 on a trailer and have seen a brochure depicting a system used to raise and lower the mast that uses guide lines or cables to steady the boom during this operation. Does anyone have specifications for the rigging to install this modification? What I need are the triangular plates, I believe I can get these at West Marine, installed in the port and starboard stays. I do not know which stay, inboard or outboard, I would assume inboard and the location that the plates should be installed in the stays. I believe that they would be installed about level with the bottom of the mast or about two feet off the deck.Any information on this design would be greatly appreciated.
