This should help
Here is a link discussing this, but turned around into how to take it down. The poster reversed it from the mast raising instructions in the manual and is seeking verification.Be sure to read all the replies as there is an huge error in the lowering instructions posted: don't remove the mast base pin until the mast is lowered! (Obviously when raising, you put the mast pin in very early in the sequence.)Also, as mentioned, don't bend the t-bolts on the lower shroud turnbuckles. Well, have a look, they are probably already bent. Replace them!...RickM...
