See the manual
Review page 19 of your manual or go here:
http://sbo.sailboatowners.com/downloads/Hunter_240_16790565.pdf
Under "Getting ready to sail" page 19A starting with paragraph 6 and specifically para. 7. The mast must be raked aft and if you have the mast raked to the specified dimension, then it is in the right place irrespective of how the mast base looks.
You should get a "Loos" tension gauge to make sure you have the right amount of tension on the shrouds and equal as well.
I put the trailer on the most level spot on the driveway, set a level on the top of the cabin and use a barrel jack under the trailer to level. Now follow the instructions in the manual.
Set the mast rake and refer to para. 9 to make sure the mast is straight. Having done that, para. 10 says to put 2" of bow in the mast. The upper shrouds will actually pull down on the mast (with enough pressure) and the lowers are either tensioned or untensioned to allow the correct amount of bow. More tension less bow, less tension more bow.
Sounds complicated but just do one thing at a time and it will work.
Now comes the question: "How much pressure on the shrouds?" No one will say, other than a percentage of the tensile strength of the shrouds themselves which is enough tension to tear the shroud chainplates off the boat. I use 600 lbs on the uppers and I think the lowers are around 400, but their tension in lbs is irrelevant as long as you have 2" of bow. I would do less than 600 on your boat.
I only had to do this once and when I verify once in a while they are fine. Now, I only have the mast up one week a month so I don't have a whole summer of tension to verify.
So, to sum up, if the mast is raked 6", bowed 2", straight side to side and plumb, then don't worry.
