Snigle Handing is easy
Dear Greg,I have a 1995 H26 and just dropped the mast again last week. I am able to drop and raise the mast by myself without excessive force or mental stress. When raising, bring the main sheet back to the winch and crank it up. You can even stop and rest. Letting it down, I stand on the bow and just let it down with the main sheet - just like it says in the owner's manual. I think it is a very well designed system. One modification I made was to replace the original mast pin with one that is slightly smaller in diameter (5/16) and ground a bevel onto the end opposide the head. It makes it much easier to get in and out. I just bought a 5/16 stainless bolt 6 1/2 inches long (I think) cut off the threads with a grinding wheel, beveled the end, and drilled a hole for the cotter ring. It works great.Ned ChristensenSecond WindEugene, OR
