mast needed H23
G
Grymkiwi
mast solved??
:) thanks, us spars got back to me straight away. $1500 for the mast (yikes). Before I bite the bullet on that , anyone know anyone else with an H23 or 23.5 (or any other boat with the Z-190 mast profile that they are scrapping ??
-na -NA Anywhere USA
bite the bullet
When buying a used mast which is rarely found, you will need to inspect it closely first. Any major dings or too many holes, walk away. best to replace with a new mast and US Spars is priced moderately.
Jun 5, 2004
209
- - Eugene, OR
before you buy. . .
you might check to see what was on your boat originally. If you check the archives, you will discover that Hunter put three different brands of mast on the h23. I presume, but do not know, that they use the same fittings and rigging. $1500 is a bit more than I'm willing to bet on a presumption if I don't have to. As for the used mast, I strongly endorse Crazy Dave's warning. Not only is he a known expert, but it makes good sense from a purely practical point of view. Good luck and happy sailing.
Jim Kolstoe, h23 Kara's Boo.
Oct 16, 2008
1
Hunter 23 Sanibel
thanks for your posts, I bought an old H23, still sailing but in poor condition. I've scrapped it for parts, namely the mast and bought new rigging from US Spars. All is well.
