Mast Mount Radar
H
HAL
I’m trying to keep weight aloft down. Does anyone know if there is a difference in the weight between the various 18” mounts? Scanstrut, Seaview and Edson seem to be the choices.
Sep 6, 2007
324
Catalina 320 Gulfport, Fl
If you want to save weight
have you thought about a back stay mount with a gimbled antena mount your antena will remain level even as you heel? It's more expensive but does not add much to the weight aloft.
John
Jun 3, 2006
803
Catalina 36mkII Alameda CA
back stay mount
I am presently in the process of installing a radar with a back stay mount. It's gimballed, but without the hydraulic damping that other such mounts have. This has a bolt and a nylon washer and bushing. You tighten down the nut to get the same effect. It costed $500, whereas the others cost about double this amount. One warning: make sure to measure the angle of the stay and let the manufacturer know what it is; the mount as it was sent to me does not sit level and I have to shim up the radar dome to level it. Web site for this mount is attached.
Tim R.
May 27, 2004
3,626
I also made my own
From thick wall SS tubing. It is not self leveling(yet). The photos are from the installation on my previous boat(Pearson 28). I now have it on my Ericson 35. Cost about $125 and weighs less than 10 lbs. All the weight is from the radome. I have also changed the radar to a Garmin GMR18. Tim R.
