I have a 23 O'day and have always used the tried and manly (but not very smart) method of lowering my mast. Using some strong friends, several six packs for after the mast is down, and some pucker power. I have been reading some methods that some of you use employing the use of a gin pole which I like far better. I was wondering if gin poles are a locally manufactured item. If so, what sort of dimensions are they. I am not sure I understand what you use to support the gin pole for lateral support. Do you leave the shrouds attached to the mast as you are lowering it? Is the mast really strong enough that the gin pole will not kink it? There really has to be quite a bit of pressure at that point. Sorry for all of the questions, I just want to really understand it before under taking it. Thanks for any advice. George
