I also have an 88 H23 and had some fun raising and lowering the mast. I bought the boat in april from a broker who wanted to charge me $80 to lower the mast. I felt this is a normal operation for a trailerable boat and I should be able to do it myself. With the help of the forum and my 62 year old father we were successful. Their are a few variations on raising and lowering out there but this is the one we used. First, I loosen all the standing rigging. Next, attach a line to the foestay(still attached), run it through a block secured in the anchor locker, and back to a winch. Now the fun begins! If the boat is stable ( on trailer) and the wind is light, two people can handle it. If not, three people (two at the mast(stronger) and one on the winch(weaker)) can do it safely. Let the winch person stand on the cabin top to steady the mast and push it forward to loosen the forestay. Disconnect the forestay from the anchor locker. Make sure the line is secure. Switch places at the mast and have the winch person get tension on the line. The mast will come down easily until it reaches about a 30 degree angle. At this point you should be able to reach the mast from the cockpit seats. The winch sort of loses its mechanical advantage at this point. Lower it into the craddle, pull the pin (holding some down pressure on the mast) and walk the base of the mast forward. Simple right!?We have successfully rasied and lowered the mast three times with this technique. I keep the boat in the water so I will only have to do it twice a year.I have heard of a MacGreggor mast stepping system that can be mounted to the H23 which uses a separate set of side shrouds and a gin pole. This system should add safety and simplifiy the process.SteveS/V SALT SHAKER
