Mickey Goodman
I went to the boat this weekend to start the commissioning process and found that water had leaked down the mast into the cabin and accumulated on the table.I had previously had an inspection plate installed at the base of the mast.Has anyone have experience with this type of problem?I was thinking about spraying some type of sealant through the inspection plate only the bottom of the mast step plate (deck mounted mast) to seal it from the top.Any recommendations of the type of sealant to use or the process to get it accomplished would be appreciated.
