Another vote for re-bedding
Best solution is to re-bed. Also check to see if the core is wet, it would be preferable to clean out any soggy wood and use epoxy (or new wood), seal any exposed areas with epoxy, and then use a good polysulfide sealant. If you need a temporary solution to hold you over until you can do that, use Captain Tolley's creeping crack cure.Manny
