Mast Leak
Kevy
Nov 27, 2018
49
Hunter 320 Nanaimo
Hi all! Hope everyone is surviving the apocalypse without much difficulty.
I have an unfortunate leak down the compression post in our Hunter 320. Rain or washing results in water running down the post. It runs to the bilge so isn't a large concern, but obviously there's an opening in a vulnerable spot under the mast.
Being a newer boater I'm not sure what's involved with either unstepping the whole mast or just having it temporarily lifted long enough to clean, find the spot, and shove 3M goop into holes.
I'd like to change the anchor/steaming lights and install a new wind vance at the top of the mast, clean the spreaders, etc., so maybe just having if taken down for a day is the way to go? Other than removing the sails though I'm not an expert in how to take the mast down dealing and dealing with the standing rigging. Does anyone have a suggestion either for just the leak or a good boatyard to go to on Vancouver Island to get this all quickly done?
PS - I've posted before about the bottom and happy to report it's all done (though turns out the gelcoat had been mostly removed before) and has 4 coats of nice new epoxy and 3 coats or antifouling. With that and the new Campbell Sailer prop we added over a knot motoring home).
Feb 10, 2004
4,255
Hunter 40.5 Warwick, RI
If you have several jobs to do on the mast, I would just take it down. Yo are likely to need a couple days (unless you find that nothing ever goes wrong and you work much faster than me).
Mast leaks are velry common and there is a lot of info on this board about how to eliminate it. Do some searches and read everything you can find. Typically there is a PVC tube that extends 3-4" above the mast step that all of the wires pass through. The wires are sealed and the PVC tube is caulked into the mast step. The other good practice is to ensure that there is a loop of the cable bundle in the mast so it water is running down the wires it drips off instead of exiting in the cabin.
I am guessing here Kevy, that this is not your first challenge. Not a lot to go on but I think that your boat is a deck stepped mast. If you have a compression post inside then the leak would be under the mast.
Mast removal would give you an opportunity to fix it long term. As Rich wisely shares, this is an opportunity to do those things like inspect the rigging and make any modifications like getting the electrical things to work on the mast, that you always wanted.
As far as finding the leak you need to inspect the mast step. Removing it will give you the opportunity to clean it have it painted etc.
Water always comes down the inside of a mast. There are plenty of holes for rain and condensation to build up. What is up must come down. So your mast was built with some weep holes to let the water out of the mast and flow off the deck back to the sea. These often become blocked. You might improve your situation by cleaning all the weep holes that are at the bottom of your mast. Get the water out before you raise the mast. Once all is cleaned up you can seal the mast step (that metal thingie the mast was sitting on) to the deck using some 4200. Apply generously (but not the whole tube - you have to clean up the excess so have a lot of paper towels available), seat the step on the deck and screw it into place.
Rich suggested hoses that the wires go through. Here is a picture of my mast step attached to the deck. The hoses go through the mast step. They are sealed in the step with some of that 4200.
D17E5D26-8846-4EC2-BD16-ED6B79434687.jpeg F47C1425-E703-4362-8E45-E24AF59398BE.jpeg
Hope this helps.
If your mast is a through the deck mast and sits on your keel, then you want to make sure the mast is properly braced at the deck level and you need a mast boot to wrap around the mast like a rain coat. This stops the water from running down the mast and covering the floor. Water still runs down the mast but that water end up in your bilge.
Good luck.
Likes: Rich Stidger
Kevy
Nov 27, 2018
49
Hunter 320 Nanaimo
Wow guys. Great replies, thanks much. It is indeed deck stepped so your advice is valid. I will first check all the weep holes to ensure they're clear. I will find a place to help get the mast down - hopefully a place around here with some good advice. I'm not expert enough to know all the steps involved (pun intended) of unstepping the mast (i.e. standing rigging, lines, etc.) without messing it up so would appreciate learning from knowledgable folks the first time it's done.
Cheers all!
