Mast head wiring question
jtm
Jun 14, 2004
314
Hunter 28.5 Dataw Island, SC
I have my H28.5 mast down and in process of replacing the steaming torpedo lamp with a marine beam LED combo anchor/ foredeck light.
I pulled thru the new wire with an added wire ( for the foredeck light)and plan to combine the common return wires of the steaming/foredeck with the return of the anchor light as I only have 4 connector lugs to the round mast base deck connector -to panel wiring.
Moving to the mast top plate where I want to install the marine beam LED ( w photocell shut off) I found in attempting to remove the old perko lamp, one perko base fastening machine screw backed out of the top plate tap, the second unfortunately seems nut fastened under the mast-top fitting/plate.
So my question, Do I need to unbolt all the mast head thru bolts to lift off the top plate. I assume so - and what will I find? Do those large horizontal thru bolts a few inches below the top tie into the top plate or do they just act as some pulley wheel pivots for the halyards.
Secondly, what is used to hang the anchor lite wire? I assume perhaps the immovable anchor lite machine screw/bolt is doing double duty as anchor light fastener and maybe there's a nut that holds a clamp fitting holding the weight of the mast wiring.
I have never opened up that mast-top plate and wonder what I'm in for . Any input as to what I can expect to find is appreciated.
Thanks
Jim mccue
