Sorry..
Quote:"MaineSail - you might explain your set-up a bit more. Sand is not that familiar with navigation lighting, and might think that your stern light (as shown in your picture) is your anchor light."Actually there are two lights in that photo on my radar pole. One of them is my stern light and I mounted it there, above the dinghy, so it could be seen when the RIB is on the davits. The second light, my LED anchor light, is actually hanging upside down next to the radome. It's mounted upside down so it's beam is not greatly reduced by the radome itself in a 360 view. As for 360 degree compliance I have circled my boat many times and it's 100% visible because that light is illuminating my entire cockpit, stainless rails blimini etc.. I also have, when possible, annual CG inspections and the CG thinks the light is fine and said I am in compliance with it. I also asked about the distance visibility and they said unless you are anchored in a very open ocean type of anchorage with heavy ship traffic not to worry and the distance rating is only for the "specifications" of the lighting device itself. Of course I seem to get different answers to different questions each time I have an inspection. That being said, we have anchored many times with cockpit based anchor lights and never once has the USCG stopped to tell us we were not in compliance and this includes anchoring in Boothbay Harbor within a 1/8 of a mile of USCG station Boothbay. While I do use an LED anchor light on my radar pole I would not however use an LED at the mast head. I've yet to witness one or try one, & I have a drawer full of LED bulbs I've experimented with at the mast head, that does not look like a bright distant star. The blue light given off by an LED bulb can, in my opinion, dangerously reduce the distance scale of your vessel and depth perception when mounted at the top of a spar. I've approached my own boat's with LED's at the mast head and clearly thought it was considerably further away than it actually was. I don't seem to get this problem with incandescents at the mast head as much as I do with LED's unless it's the Davis Mega Light which I've also tried and stopped using due to "depth perception" issues. Hope that helps clarify?In summary I use: One Anchor light with incandescent bulb at the mast head (my back up)andOne LED anchor light on my radar pole (my primary)
