Block type
Eric - I have been replacing the stock blocks with Lewmar. Garhaeur will do just fine as well. Actually, anything is better than the stock stuff.I am curious as to what kind of set up are you trying to achieve?In case you are curious, I am flying an assymetrical spinnaker. It's not that great for downwind speed, but really easy to set, fly and douse. I have a block attached to a hole conveniently placed in the anchor plate for the tack line. The tack line is then run back aft through one of the clutches. I wish I had a sprit like the J105 or J120. In any case, I am planning to add a full spinnaker to my wardrobe for when I do the Ha Ha in '08.
