On a 1979 30' Hunter Cherubini, The mast rests on a "T" located in front of the bilge area. When I bought the boat about 7 years ago, I noticed that the previous owner had attached 2 steel plates to the vertical part of the "T". Some time ago, in this forum I read that the "T" on these Hunters can be problematic and with time it will get weak, so I understood what he was trying to do.
The first picture is what's left of the "fix" The metal plates were not prepared, painted, or otherwise placed in there to last. Both plates just fell apart in the salty environment of the bilge. The "T" seems to be in good shape (considering), and I have not clean it yet.
My idea is to replace the plates with heavier gauge steel. I would also prep the "T" and the plates with paint etc. to reduce the rust to a minimum. Before I do this, I would like to get some ideas from owners that have had the same issue. Pictures would be appreciated
. Thank you.
