Mast Erection Pin
6
Chrysler 22 Bon Aqua, TN
I am looking for a Mast Erection Pin for a C-22. Just bought my boat, and of course that one minor piece is missing? Any suggestions....
Jun 9, 2008
1,852
- -- -Bayfield
Not sure what you mean by a mast erection pin. Chrysler used a cast aluminum square peg that had a little bend in it. The base of the mast had a rectangular slot which you placed over the peg and then you walked the mast up (with the side stays and backstay attached, of course). If you have a mast base that takes a pin, then it was changed from the original design and you have to give us more info as to what type of hinge arrangement you have. You can always get a bolt the right diameter and length (stainless is best) to get you buy. If you use a mild steel bolt, use it only temporarily until you get the SS bolt or pin. More info, please. Then I might be able to help.
Jul 17, 2009
94
Endeavour/Chrysler E-32/C-22 swimming pool
If your talking about the pin needed for the gin pole in to the base of the mast for raising the mast, I found short rod stock at Lowes that worked well.
Ken come join us at www.chryslersailors.com
Sep 19, 2010
6
Bill, The base is there, it os for the gin pole, to attach the boom to the mast during the raising. Mario, good idea I will check that. Thanks
