Repair Before Cutting
I'll repeat the email I sent you on the mail list, just in case folks here (that aren't on the list) want to agree, disagree, or add to it:First of all, your damage is not as extensive as you may think. Your mast didn't really break, the holes for the mast hinge ripped out, but that's not a major problem. However, I suspect you have more problems than the mast hinge. First, on the mast:The mast hinge assembly is the thing that's in your hand. You can buy both parts of the hinge (the part that attaches to the deck, and the part that attaches to the plug), the plug (it's the soft aluminum part that fits in the mast), and new pins for a little less than $100.Were that my problem, I would do one of two things. The FIRST thing I would try is to mix two part epoxy with aluminum filler to fill in the holes and torn out area. I would then smooth it out with a Dremel, sander, whatever, and redrill the holes. Then I would attach it all to a new mast hinge. West Systems has a link that describes the type of aluminum filler that I'm talking about. While this link describes a different project, you can see the information about aluminum filler, and apply it here. Here's the link:http://www.westsystem.com/ewmag/14/Stardustwindows.html If that didn't work, I'd simply saw off the portion that's ripped out, making that the new bottom of the mast, but I'd really only do that as a last resort. You'd have to remember from that point on that your shrouds and stays are "non-standard" and would need to be cut shorter.The mast is really not broken. That portion of the mast is only used to keep the base from sliding around, so it doesn't really have to be extremely stout. In its original configuration, it's only got 4 small screws holding it in place.Which brings us to the REAL problem:What caused the mast to come down? This is NOT the "root problem". This hinge giving way is because either a shroud broke, was WAY too loose, or a chainplate or fitting gave way. That is your real issue.If it's a chainplate, you probably would have mentioned it. That would be a pretty big job (I know, I just finished replacing mine, which is why I know how much the mast hinge costs). My stronger suspicion is that a shroud gave way, or a stay. If that's the case, that would definitely need to be replaced. My strong suggestion would be to replace ALL of the shrouds and stays. While this is a bit of a financial bite, it's something that MUST be done from time to time anyway. A new set of shrouds will cost $480 from D&R marine. No matter the reason for the mast coming down, the shrouds are almost certainly damaged now. I would replace all of them. I strongly suspect that was the primary cause for the dismasting.New mast hinge - $100Materials to repair mast base - $50-$75New shrouds and stays - $480Total cost of repair - $630Peace of mind while sailing the next 10 years - Priceless
