Mast bend on H-340
1
- - OKA, Quebec
What is the maximum mast bend prior hoisting mainsail and also when mainsail is up, expressed in inches, and position of this maximum bend. Thank you.
Other Catalina 30 Tucson, AZ
Question?
If your Hunter mast is anything like a Catalina mast, which is like a telephone pole, you won't be able to bend it like you would a J boat mast for example. All you can do is "rake" it back. I'm curious why you want to preset the mast bend?
