mast base
Terry
I bent my mast base for a 1984 222 o'day. Does anyone know where I can get a new one?
bob
try this place
www.drmarine.com/products, i tried to open it before i sent this to you and it would not open. they may be having a little trouble with their site. they have lots of o'day parts.
bruce cornell
got bent
if you have a 2 pin ss tabernacle, or even a single pin, ment my 2 pin last year, and a local machine shop was able to straighten it back into shape with their press, might work for you. also check dwyermast.com.
RobG
337
Ericson 28 Noank, Ct
My '84 222 has Dwyer and has this tabernacle.
Apparently Oday used a couple of brands for the mast/boom. If yours is Dwyer they still make all of the stuff. I added the organizer plate to mine this year and like it.
Jan 24, 2005
4,881
Oday 222 Dighton, Ma.
Replace with a Stainless Steel Mast Tabernackle
You may want to think about having a Stainless Steel hinged tabernacle plate installed on the bottom of your mast and do away with the sheave on the bottom of the mast for the Jib halyard, if you have internal halyards. The Jib halyard can exit through the mast next to the Main Halyard. I had this done years ago when I lost my old mast, and it worked out beautiful for me. I mounted the tabernacle plate on top of another stainless Steel plate w/ holes in it for accessories and etc. on a piece of teak where the old mast tabernacle was. Of course, if you want to go with the original mast tabernacle, Rudy at D&R Marine in Assonet Ma. might have it.
