Is this standard or a user modification?
Any idea how the pin is removed?
Thanks Claude. I had not tried but I have the confidence now. I bought a cover plate from Rig Rite with the purpose of creating an access hole.Standard. I've pulled mine by just inserting a large flat blade screwdriver between the head and the plate. Release tension on the halyards before you do so. It is just a push pull pin. You just need to re-align the sheave and re-insert pin to re-install. Suggest you cut a window in the mast as in pictures. Makes reaching those wires for connect and disconnect while stepping or un-stepping mast much safer than working with your hands under a suspended mast. Good luck
