Last year when I lowered the H 26 mast I had a hard time removing the bolt that mounts the mast to the base and the mast pivots up on this.
I had to hammer out the bolt and it's bent up.
The big question is what size is that bolt? I'd measure it but the boat is some distance away right now. The sell a "pin" here that is 5/16 in diameter... I think what I removed was larger. Is it a standard size?
Could it be 7/16's?
Also, the gin pole I use to step the mast has no groove on the bottom. I have been successful with out the groove but should I cut a groove into it?
Thanks in advance
Could it be 7/16's?
Thanks in advance
