Drill bit
I use a regular set of drill bits from Dewalt. They are multi-purpose and can be used for wood, metal, etc. The boat wont be hard to drill through. Start with a small bit and then go larger. If you can, have someone hold a piece of wood against the cabin ceiling so that it doesn't split up when the bit comes through.Here's a trick for drilling the smaller holes for the screws to hold down the clam. I got it from a CD (Catalina Direct) video. After you drill the screw hole (for example using a 1/8" bit) then take a 1/2" bit and turn it, using you hand, on the 1/8" hole. This will widen up the top of the whole and prevent the fiberglass from breaking up when you screw the screw in. It used to drive me crazy when bits of gel coat broke away when I put screws in. Just give the 1/2" bit a turn or two and it wont happen.By the way, I was a skeptic about spending the $29 for a CD video but then I got the one on standing rigging and got a few tips that were well worth the $. Randy
