Mas-technologies instrument gauge for Yanmar
Jan 4, 2019
61
Hunter 50 Halifax & Martinique
The Mas-technologies instrument that displays the Yanmar gauges on my Hunter 50 has a large brown spot on the readout as seen in the picture. The display seems to be visible under this stain and it may be mould under the glass in the case. Can the outer case be removed? I couldn’t find the company and they may no longer be in business. Has anyone seen this or know if it can be fixed. Any ideas appreciated.
May 27, 2004
2,059
I think the "spot" is UV degradation of the face.
I think it's going to require a new instrument. :(
Likes: JoeWhite
Jan 4, 2019
61
It was fine when we left it in June and was covered continuously until I uncovered it yesterday. The inside of the cover had quite a bit of mould on it though.
Jun 1, 2009
1,856
Hunter 49 toronto
Ok,
The reality is that the display was almost as unreadable without the discolouration
Just tie your chartplotter into your engjne feed, and you’ll have all your engine data in full colour in front of you
if you need directions on how to do this PM me.
btw, the plastic cover on my Teleflex guage hasn’t been off since 2000. ( when I figured out the plotter link)
Jun 1, 2009
1,856
Hunter 49 toronto
Ok,
Other option is to pop in a raymarine i70.
It has full engine functions, and is actually readable.
Jun 1, 2009
1,856
Hunter 49 toronto
contact gaugesaver.com 904 701 9726
Very interesting
Never knew these guys existed
But…. The fundamental issue is that this guage was always totally unreadable.
it is a good plan to tie the engine data to the plotter. It’s a very inexpensive thing to do, and having your engine data in full color is very useful
Jan 4, 2019
61
I took the old instrument apart. You carefully peal apart the 2 pieces of glass inside. The old dark film that is inside needs to be scraped out until you have bare glass. Then cut out a new piece of polarizing film and stick it onto the glass. Check the orientation first as it will affect the display. Put it all back together and you have a new instrument and saved yourself $900. Just did mine today and it worked perfectly. Lots of polarizing film available on Amazon.
  • Helpful
Likes: ggrizzard
Jan 4, 2019
61
Three months later and the display is blank again. Time to hook the readouts up to the chart plotter.
Jun 1, 2009
1,856
Hunter 49 toronto
The original instrument had a horrible UI, and the display was unreadable
Yes, hook up the N2K feed to the plotter.
Jan 4, 2019
61
Instruments are now hooked up to the plotter which is a much better solution.
Aug 13, 2014
6
beneteau 473 saltspring island
Hi, I have a 2012 Hunter 50AC and the Mas works except for the engine hours that doesn't show and is needed. If I could also have it on my E120W Raymarine chart plotter that would be fine. Can you please point me in the right direction to do that.
Jan 4, 2019
61
The N2K backbone from the engine module ends at the MAS display. The splitter (or T) for it is in the port cockpit locker behind the display. Remove the terminator from the splitter and replace it with a N2K to STng cable that will run to the STng splitter in the instrument pod above the port wheel. It replaces the terminator on that splitter. (I moved that splitter to the cockpit locker because of the cable lengths I had) To prevent power from going from the N2K network to the STng network, a power isolator is inserted where the N2k network enters the splitter for the MAS display. The new terminator that will now services both networks is inserted in the splitter that is near where the N2K cable exits the MAS engine module. This module is situated below and behind the turbo.
Parts required:
1. N2K to STng cable
2. Power isolator (Anchor 2701113)
3. N2K terminator. ( use the original one from the MAS display splitter)
4. Because I had a short N2K to STng cable, I replaced the black and white STng spur cable in the instrument pod with a longer one so I could relocate that splitter to the cockpit locker. If you get a long enough N2K to STng cable you don’t need to do this.
