I removed the registration numbers from the Cat. 22 that I just bought. I also removed the name on the side of the boat. The hull is a different shade of white under the numbers and name. I tryed to rub that out but did not have much luck. Is there anything that I can do about this? Will this just fade in time and if so about how long does that take? Any help will be helpful. Thanks Dale
