Mark II Catalina 30 1987
3
- - VA
I am looking at purchasing a 1987 Mark II 30'but I can not find any details about this boat. It has a winged keel but nothing in the specs about the Draft. Request any information about the Mark II and where can I find details that make this different from a regular 30. Thanks Frank
Dave
4'10'' draft
I believe the draft of your '87 is the same as my '89, which is 4'10". All '87s are Mark IIs; the Mark II model replaced the original design in '86. The major difference is the layout of the cockpit in a "T" shape for wheel steering. The C30 owners association (link below) has historical info on the model changes. The C30 is a terrific boat, and a great value in the late-80s vintages. Good luck.
May 12, 2004
1
- - Miami, FL
'87 draft
I switched keels to a wing and was told that the draft would be 3'10". When I measured it ended up at 4'3". Guess everything I had on the boat made it deeper in the water.
Dan
3'10'' is correct
check with the C30 National Assc. web site. they have the orginal Catalina brochures for all models. I always look for 4 ft of water and she always floats. love my C30, I believe you will too.
Dick
Mark II mods
Frank, I have C30 #4821, 1987 vintage. The Mark II modifications are Universal 25 3-cylinder engine, t-cockpit, halyards led to the cockpit, flattened traveler, revamped nav station/electrical panel and some aesthetic changes. I found these to be significant for this single-handed sailor to make a point of purchasing a Mark II. Good luck and Fair Winds.
