might not be a leak?
It is possible, that this water was not outside water, but had collected in a low-point in the bilge while on the trailer, then ran into the bilge after launching. Far-fetched, perhaps, but worth considering. Things to check, is the CB pivot bolt weeping, is there a small crack in the hull, what about the cockpit scupper drains (hoses as well as thru-hull fittings), sink drain thru-hull, could be a small crack at the forward end of the CB trunk. Did you launch into saltwater or fresh, if saltwater...taste the bilgewater (dip finger, lick and spit out). I would not panic over a few ounces over 2 hours, but I'd be sure and track down the leak and fix it.
