Hi Friends,
I'm in the process of setting up my recently purchased
Mariner 2+2 and have a question about the swing up rudder
The top half has two Pintles, between these is a grove
that lines up with a grove on the bottom half of the rudder.
I believe that this was for a down haul to swing the rudder down
while sailing. Above the top Pintle as seen in pic #2 the grove
dives into a tunnel that exits above where the tiller would be.
Seems to be a fairly simple set up except for the fact
I can't figure out how the bottom of the cable
attaches at the end of the grove in the lower half of the rudder.
See Pic #3 The grove dives into the wood for about an inch
and unless there is some fixture that is painted over, just how is the
cable anchored? There is an odd wood screw that seems to do nothing
where this anchoring device should be.
Is this some kind of FrankenRudder set up by the previous owner?
All ideas are welcome
Thanx to all in advance
Neil
Neil
