What is the difference between marine and pressure treated plywood, if any?The reason I'm asking is that I need to add a wood spacer piece between the hull and a new thru hole fitting nut. There are wood spacers under all the thru hole nuts on my Hunter. I assume they are there so there is a flat surface for the thru hole fastening nut to work against.I dont want the wood to swell so much that it puts excessive perssure on the fitting.ThanksGeorges/v Windswept
