Not suitable for your boat
For one thing, the VacuFlush costs about $1,000 plus installation (only a dealer can install it) which averages at least another $1,000. For another, by the time you find room for the vacuum tank, vacuum pump (or combination "vacuum generator) AND a holding tank--all of which are components separate from the bowl assembly, you won't have enough storage space left for an extra roll of toilet paper, much less anything else. You can see all this for yourself on the SeaLand website (link below).If you replace your portapotty with anything other than another self-contained system, you'll still have to install a holding tank...and unless the boat already has one, a thru-hull and seacock for the toilet flush water intake. You'd also be trading carrying the portapotty off the boat for a whole lot of additional maintenance. However, there IS a solution:Replace your small 2-3 gal portable portapotty with a larger 5-6 gallon model permanently installed and fitted for pumpout. No new plumbing except a pumpout hose and vent line ...twice the capacity, and it pumps out like any other holding tank.
