marine head not flushing
orion
Nov 19, 2008
52
Hunter legend 35 City Island
Recently a friend used the Raritan II head and it would not evacuate the water. Before I tear it apart I am wondering if anyone knows whether it is likely to be the flapper valve or the joker. Any thoughts would be appreciated.
Was the friend a woman? :):):)
WADR, what difference does it make if you have to tear it down?
Hunter 25_73-83 NORTH POINT MARINA/WINTHROP HA IL
In addition to the two above considerations, don't forget the possibility of a clogged discharge line/hose from your head to the overboard discharge through hull. I have encountered this twice and the hose was completely choked with calicification/debris that was literally cemented to the inner walls of the hose. Good luck and good sailing, Ron
Dec 2, 1997
9,011
- - LIttle Rock
More likely to be the joker than the flapper, but...
There are other possibilities too...I need more information before I give advice:
How old is the toilet? What exactly are the symptoms--increasingly hard to pump? Pumps maybe too easily, stuff just swirls in the bowl? When, if ever, was the joker replaced? Have you made sure that the tank vent isn't blocked? A blocked tank vent would pressurize the system, creating backpressure that would prevent the toilet from flushing.
