Yes, You just need what is called an
"OEM/Sensor" and a mapping program that supports GPS (most do now) if the free Maptech program mentioned works it would be a good choice. Many companies make the sensors, I've added a link here to a place with the Garmin GPS 18 for $90 with a USB connection, it's typical of those made for laptops. I've used a Garmin GPS 16 which looks like a hockey puck, and there is also a GPS 17 that looks like a typical marine external GPS ant. The link to Garmin's page of sensors is: http://www.garmin.com/oem/They can be purchased with USB, Serial or bare wires (roll your own) The LVS or HVS stands for Low or High voltage, Low uses ~3 volts (DC) (USB or mouse plug) or high voltage 12-16 (DC) (Serial). Easiest is USB but serials work fine too.Some years ago I ordered some with serial for data & a Mouse plug for power and they were less than $125.I have even used Microsoft MapPoint (a land map program) at sea, no detail, just an arrow in the ocean of a roadmap.
