Marine GPS
Michael Flood
Is there such a thing as an inexpensive GPS kit that can be downloaded on a laptop so that I can use my laptop screen to check positions out? (Marine only)..I'd like to go out on a blind adventure, but not get lost... Thanks
Feb 17, 2006
5,274
You still need a GPS receiver...
But you can get charts and a chart program for free from Maptech.com. Go to this link: http://www.freeboatingcharts.com/ At the top of the page, click on DOWNLOADS. Right side of the page in the blue box, 4th link down, click on: Digital Charts/ChartKits (& 'FreeBoatingCharts.com') In the TOP DOWNLOADS box, 4th link down, click on: Chart Navigator 5.07c - Full Product (no charts) I understand that the software will interface with GPS. You can also get Raster Charts from NOAA or from Maptech at: http://www.freeboatingcharts.com/index.cfm?page=download Hope this is what you were looking for. If not, sorry.
Ross
Jun 15, 2004
14,693
I think that you need
to learn more about the Global Positioning System. The devise that we hold in hand is a very sophisticated receiver, computer and display. It can not be replicated in a computer program. There are however GPS receivers that can be had for less that 150 USD and maybe for less in Canada. The attached link will serve as a very good primer for understanding GPS. G'luck. Ross http://www.garmin.com/aboutGPS/
Dec 3, 2003
2,101
If you are looking...
...for a site that you can download a chart and pinpoint a lat/lon position, try the following link. http://www.maptech.com/onlinemaps/index.cfm?CFID=27265&CFTOKEN=18625917 Then select "The MAPTECH Map Server". Take it from there. Then select the type of map tab and move your cursor over the chart.
E
Ed
yes
Look for gps for laptops on your searchengine and look up delio its a gps reciever that you can use with a laptop.
Catalina 320 Dana Point
Yes, You just need what is called an
"OEM/Sensor" and a mapping program that supports GPS (most do now) if the free Maptech program mentioned works it would be a good choice. Many companies make the sensors, I've added a link here to a place with the Garmin GPS 18 for $90 with a USB connection, it's typical of those made for laptops. I've used a Garmin GPS 16 which looks like a hockey puck, and there is also a GPS 17 that looks like a typical marine external GPS ant. The link to Garmin's page of sensors is: http://www.garmin.com/oem/ They can be purchased with USB, Serial or bare wires (roll your own) The LVS or HVS stands for Low or High voltage, Low uses ~3 volts (DC) (USB or mouse plug) or high voltage 12-16 (DC) (Serial). Easiest is USB but serials work fine too. Some years ago I ordered some with serial for data & a Mouse plug for power and they were less than $125. I have even used Microsoft MapPoint (a land map program) at sea, no detail, just an arrow in the ocean of a roadmap.
