Marine battery and solar panel questions
Aug 17, 2013
1,343
Pearson P30 202 Ottawa
hey everyone, I'm looking at marine batteries, but I'm stumped at different group size, what is the main difference between a group 24, 27 and a 31? is it just the physical size? what should I be looking for? I don't mind spending a bit more but only if there is a good reason to spend more.
I'm looking at getting a second battery for my upcoming trip, so I'll have to figure out how to wire the second battery.
now for the solar panel questions, what size should I be looking at for a small 23ft trailer sailer? how many amps (watts), where do you recommend installing it, I dont have a bimini (boom too low) the wiring seems pretty straight forward.
my current setup on my boat has the Bbq on the aft starboard rail, the rest on the rail on the port side and the sides of the pulpit are free (the sides are angled down).
I know the subject has been covered before but I can't find the info I'm looking for, thanks in advance for your help
Fred
Your power needs are not too demanding so....
I'd size the panel to the physical space you are willing to devote to it then get the biggest panel that fits in that space conveniently
Nov 26, 2012
2,315
Catalina 250 Bodega Bay CA
I have a pair of size 24 batteries and 2 ea. 80 watt solar panels. In your case the same would be fine for your batteries but probably one 80 watt panel and controller would be fine. Hang it on your stern rail and you can use plastic pipe for props to put it up to a decent angle. Basic concepts to start. Chief
Aug 1, 2011
3,972
Charge controller. Don't forget the charge controller, and don't cheap out on it. It will save your batteries.
Beneteau 323 Annapolis MD
31 is the largest of the three, amp-hour-wise. Get the largest you can fit in.
Nov 26, 2012
2,315
Ron: He has a small boat like mine. Huge batteries are not practical due to weight plus he needs to select a battery the same basic battery type /size he has installed now. One more caution; if existing battery is old just get 2 new matching batterys.
Hello Meriachee! Chief
Jul 1, 2010
990
Catalina 350 Port Huron
The difference is physical size and capacity. Here's a link with info on capacity and size of the various battery groups:
https://www.batterystuff.com/kb/tools/bci-battery-group-sizes.html
As far as what you need, try adding up what you expect to use in a day in amp hours, and use that to judge what you might expect to need for battery storage. Do the same to size the solar. Browse Mainesail's forum and his website (compass marine). There's a lot of good and accurate info on batteries and solar systems there.
Jul 1, 2010
990
And just a data point for you. We used to own a Hunter 23.5. It had one group 24 battery in it. We only had lighting, fishfinder, charging of our tablets and phones to worry about. Motor was manual start. We used a 15 watt solar panel to keep the battery up when at our slip. We just put it out on deck when needed and could move it around...no permanent mounting. This worked fine at our marina. When we traveled with the boat, it wasn't quite enough for daily use. The boat also had shore power, so we just planned on doing a full charge at a slip, every few days. Current boat has refrigeration, and no shore power, diesel motor, so our battery and solar installation is much larger and more involved.
FWIW, you can get a big bang for the buck by changing out all your interior lighting to led (likely, you can just swap incandescent bulbs for led replacements). Swapping the mast light for led would be a good idea too.
Likes: The Garbone
Nov 7, 2012
678
1978 Catalina 30 Wilbur-by-the-Sea
We had a C27 that was the exact same setup, 15 watt, our C30 we have a 50watt panel also loose, once we go full time it will be 200+watts on the bimini.
Batteries should be matched in size and age, in general they should be replaced as a set much like tires. Reminds me of passwords on my work computer, have 3 passwords I need each expires at a different interval. I just change them all together at the interval of the shortest password, otherwise you get out of sync and seem to always be changing the damn things out and it drives you nuts.
Chief said:
Ron: He has a small boat like mine. Huge batteries are not practical due to weight plus he needs to select a battery the same basic battery type /size he has installed now. ...
That is why I quantified my answer with "can fit in". He can always install a bigger battery box if he wants to.
Aug 17, 2013
1,343
Hey Stu, I can't seem to get the links to work, It takes me to a general forum menu, All the links do the same.
SFS
Aug 18, 2015
2,100
Currently Boatless Okinawa
Fred, it works ok for me, takes me directly to a thread. If you are clicking on it, and it doesn't work, try cutting and pasting it into the browser URL line. Good luck.
Just as another option, I've cut and pasted from my browser to here:
http://c34.org/bbs/index.php/topic,5977.0.html
Nov 26, 2012
2,315
Garbone: 200 watts of solar coupled with about 200ah battery bank sounds like a good basic self sustaining system. With my 2 ea. 24's and a pair of 80w panels my boat is completely self sustaining indefinitely. This encompasses use of a 2.7cu ft DC , .7a,reefer as well as rest of DC system. Chief
Mar 1, 2012
2,182
Cruised full time for 2 1/2 years on my 25 footer, using one group 27 battery and a 32 watt solar panel. Had to pull in and connect the battery charger twice during that time. If I were buying new now, I'd get a 50 watt panel.
Agree big time on the charge controller. I've used a Morningstar Sunsaver 20 for years now with excellent service
Aug 1, 2011
3,972
Sunsaver seems like a decent unit.
Howdy Chief - Where ya been?
JCall
May 3, 2016
66
Macgregor 26D Ceasars Creek
fred1diver said:
why 2 matching batteries?
Batteries have an internal resistance that is best if matched. If you divide the current draw on the battery by the batteries voltage at that load, you will find the internal resistance of the battery. The battery with the least internal resistance will take most of the load. The high(er) internal resistance or "lazy" battery will not take its share of the load. Batteries in parallel should be put into service in pairs.
May 23, 2004
3,319
I have a 23 foot trailer sailor.
My set-up, because I do extended cruises, is to have 2 GC2 batteries wired in series to get 12 Volts. I have an outboard that has a small alternator but that is way too small to replace the power I draw since I tend to use a lot of electronics. My main charging system is a 100watt flexible solar panel that sits on my bimini. It runs to a Genasun GV-10 Charge controller.
Overkill? Maybe...but...
I run an autopilot (tiller pilot) a lot. I also run a GPS that is hooked up to my VHF and I get AIS targets. I also use lights in the cabin at night, mostly LED, and my anchor light is LED. My stereo spends a lot of time on and once in a while I use a small inverter to charge my laptop. I also spend a few weeks out without ever going into a dock to charge. I have pressurized water, cold only, and even have a cockpit shower in the boat.
To better answer your question consider what your intentions are. How long do you plan to cruise? How remote are you cruising? How much power do you THINK that you will use? How much will you actually use.
