Marina plug in.
Karyon
Hunter 23.5 Red deer, Alberta
Next week we are towing our boat to Flathead lake , and we booked a slip at the marina.
The slip has power and water. We never had shore power on a boat, but I was thinking of just bringing an extension cord just to charge the phone,iPad and maybe a fan in the cabin.
Would a regular extension cord fit those plug ins or do they all have a big 3 prong type plugin like the ones RV's use.
HMT2
Mar 20, 2014
900
Hunter 31 828 Shoreacres, TX
Most of the ones I have seen also have regular 120 plug.
Johnb
Hunter 37-cutter Richmond CA
One clue would be if they offer 30 amp service, in that case it is certainly the "big round one". Also at most marinas that are properly set up ordinary extension cords are verboten.
bgary
Sep 17, 2015
53
1985 Ericson 32-III Everett
You can also pick up a 30a-to-20a adapter, which lets you plug a regular extension cord into one of those round outlets.
Mar 1, 2012
2,182
I've used an extension cord for years, and never had a marina yet that didn't have a regular 3 prong outlet on the hookup. This including the Bahamas.
One thing you really should do is get a ground fault interrupt to plug in the extension cord- You can buy then aftermarket in many places
Beneteau 323 Annapolis MD
[QUOTE....Also at most marinas that are properly set up ordinary extension cords are verboten.[/QUOTE]
In our marina, the rule is the cord has to be amp-rated for whichever outlet it's plugged into.
Nov 26, 2012
2,315
Catalina 250 Bodega Bay CA
Some marinas have removed the regular AC outlets. Spud Point Marina, Bodega Bay Ca. where my boat is now has removed all outlets except the marine ones. If you use an adapter just make sure you have a tie on the boat end of the cord to securely tie in the boat as it dropping over the side is the biggest concern. Chief
Mar 26, 2011
4,016
Corsair F-24 MK I Deale, MD
I've always found it handy to carry a male 30a locking-female 15a and a male 15a to female 30a locking. This lets me plug my boat in to standard plugs and allows me to run power tools off marine pedestals. It also solves your problem (my first boat was not wired for shore power). You can by the parts at Home Depot.
Mar 1, 2012
2,182
Should have mentioned that I carry the adapters to plug my 3 prong into whatever outlet is needed. They don't take up much space :)
Mar 26, 2011
4,016
a. If the adapter is short, nothing live will fall in the water. As you say, it is always the boat end that poses the risk.
b. Yup, I've even been in boat yards where the power was the marine locking style.
Apr 22, 2011
976
Hunter 27 Pecan Grove, Oriental, NC
If you do get a 30amp adapter, make sure it is for marine use. The RV adapter is similar but will not fit the marine receptacle.
Likes: Kermit
