Marina Fire
11,386
That is a total bummer.
In an amazing example of understatement, the marina reported today on facebook that:
'Fire this morning damaged several boats ... Owners of damaged boats will be contacted'
Jul 20, 2010
81
Precision P28 Lake Ouachita
OMG! I'm checking out my fire extinguishers next time I'm at the boat. I had no idea they burned like that!
Feb 6, 1998
11,772
Where do they come up with this stuff...
"These boats were covered up since October. There's no reason for them to start burning," said Seneca Fire Chief Jerry Sears. "It's suspicious."
I can think of a number of reasons that can happen.
*A frozen bilge pump with improper fusing and the batteries left connected.
*A battery charger left running and failure.
*An owner working on the boat and left a heater going..
*Batteries left connected
*Shore power plugged in and an AC fault.
*A slow LPG or gas leak and AC or DC still plugged in creating a spark from a non-ignition protected source...
When you consider that 55% of boat fires are electrical in nature why would it be any different out of the water with the systems still operating. One could come up with plenty more plausible explanations too....
There is a reason most yards demand boats not be left connected to power and the batteries disconnected while in dry storage.
Not saying any of these is the cause but the statement above is quite lacking in forethought.... It could be electrical in nature just as easily as foul play..
Fires like this SUCK in a BIG WAY!!!!:cry::cry::cry:
Tim R.
May 27, 2004
3,626
Hard to watch. Hopefully they are all fully insured.
I disagree with the following statement that led the chief to declare this suspicious. I hope he is doing a more thorough investigation than that.
Oct 6, 2011
678
CM 32 USA
My marina had a fire at the docks this fall, and one on the lake in the spring that killed a guy. Boat insurance is a must.
Bob J.
Apr 14, 2009
775
Sabre 28 NH
My money would be on the boyz in the hood having fun.
>> been to chicago
Nov 8, 2010
11,386
>> been to chicago
Wow bob. That's unfair. If you have been to the area, you would understand that Seneca is a mostly rural community some 40 miles from Chicago, and is in fact 90% white (10% Hispanic).
If it was not a unfortunate accident, you have to look at the possibility of random arson, or some owner trying to get out of a boat they cannot afford. In either case, I doubt that person looks anything like someone from the 'hood'.
JohnS
177
Islander (Wayfarer/McGlasson) 32 St Georges Harbor
I've lived many years in both rural and urban areas, and can tell you for a fact there are about the same percentages of trouble makers in both places, with equal representation in all races. Unless the fire chief has info he's not sharing, he's talking out his @ss. There's no real reason to believe vandalism is the most likely cause. Insurance fraud, maybe, but that conclusion should be withheld until after an investigation.
Apr 27, 2010
970
Beneteau 352 Hull #276 Ontario
Sad story. Something I always think about at our boat yard where you can walk from boat to boat, they're so close together.
Maybe it was one of the 99% :D Only kidding.
Bob J.
Apr 14, 2009
775
Sabre 28 NH
Jackdaw,
I'm not a racist nor was I trying to insinuate that someone that wasn't white did this....
Just tying to make light of a bad situation.
Bob
Dec 1, 1999
2,391
Hunter 28.5 Chesapeake Bay
Another possible cause may have been the absence of an inline fuse in the hot wire from the battery to the switch.... Do you have one?
