Manual wanted for Datamarine S-200
Styx
Sep 6, 2011
98
S2 8.0C Erie
I called them. They do not have any. They want me to send them the unit and $150 so they can look at it.
What's not working? My sounder died a few years ago, I sent it to them, they fixed it, updated the alarm module and it's been fine ever since. What's a manual gonna tell you if it isn't working?
Styx
Sep 6, 2011
98
S2 8.0C Erie
Thanks Warren. I took it apart and found one diode bad and replaced it. It seems to be working now. I didn't have the manual to tell me how it operated. I appreciate the help. I am also going to replace the RCA jack because it is corroded. Other than that, it seems to be fine.
1,096
CS 30 Toronto
bad crimp
Had it on my old boat. Took 3 years to figure out the root cause. Very intermittent symptom = "---" on the display.
The RCA socket on the back of the diaplay goes to a pair of crimped connectors which plugs onto the citcuit board. The crimp was bad. Soldered them fixed it for good.
It's a good unit.
Styx
Sep 6, 2011
98
S2 8.0C Erie
After replacing the diode, I soldered a new RCA socket on and put a new RCA plug on the wire. It seems to be ok now. Thanks for the input.
