Greetings,
The PO of our C&C supplied a new, uninstalled Whale Mk5 manual sanitation pump. The installation instructions and diagram on the box appear to disagree in where the outlet hose should terminate.
I fully understand that I'll need to install an anti-siphon device in the hose above the waterline. Just seeking confirmation that the diagram method is acceptable for this pump. Whale is not responding to email or calls.
- Instructions: “the outlet pipe should be terminated at a skin fitting well above the waterline”
- Box diagram shows the outlet terminating via seacock below the waterline.
