I have read several sailing books, so I think I have a good theoretical knowledge of the issues involved. In addition, I've consulted the archives here but still have a question as it pertains to the 23.5.My basic rule of thumb in sail trim is the old adage, "When in doubt, let it out." My issue is getting that darn top telltail to stream back, especially on winds below about 7 kts. It doesn't seem to want to join the party. I keep letting out the main sheet until it streams, but by that time I'll get some "bubbling" by the mast -- i.e. the battens bend the wrong way for 12"-18" off the luff, which seems to me antithetical to good sail shape -- and/or fluttering along the luff. I also don't see any improvement in boat speed, maybe even a bit less. I seem to recall reading somewhere that it's the top telltails which are the most important in creating drive, so you want to see them streaming back.(Also, while sailing Labor Day weekend, we got dusted by an old salt out with his wife & grandson. I don't recall the make -- an O'Day, perhaps a Catalina. His boat was a bit larger than ours, but not much, with a masthead rig. We were on slightly different courses as we neared to about 25 yds from each other, both on port tack, and he altered to match our course since we were windward. While in our windshadow, we were about even. But then he cleared the shadow & just left us in his wake until he gained enough headway to cross our bow. As he zoomed ahead, I noticed how beautifully all his mainsail tails were streaming back, all the way up the line. I KNEW I just wasn't doing something right in my trim!)As I thought it through while sailing this past weekend, I reasoned I needed more twist to get a deeper shape & let the top of the sail move further forward while the rest of the sail stayed put. I let off all the vang tension, but it still didn't seem to induce enough twist or at least the streaming in the top tail I was hoping to see. Finally I tensioned the topping lift in an effort to create more twist. It seemed to help & I think I picked up a tenth or two of speed. However, this last aspect is what I'm wondering about the most because I don't recall anyone ever mentioning that they utilize the topping lift in creating shape.I know I'm obsessing over it. I'm not racing. Notwithstanding, I am an efficiency nut & want to know I'm maximizing performance. Moreover, while cruising, say, 25 NM in a day, each tenth gets you in almost 10 min earlier. The difference between 4 kts & 4.5 kts is over 40 min.Can anyone lend any experience, strength or hope on this question? Am I on the right track in identifying the need for more twist? Does anyone use a topping lift or boom kicker to create more shape in light air? Perhaps I need to loosen the outhaul more, though I'm not sure how that would help the twist at the top.Thanks,Kevin
