Mainsail Reefing - With Dutchman
Catalina 350 Tacoma, WA WA
Hey all -
I am a new 310 owner, hull #40 (IA membership paid up a couple weeks ago...). My last boat was a C-350, and it had roller furling in the mast. This return to slab reefing is not too bad, but I am encountering more difficulty than I expected with the [not so] Jiffy Reefing.
The single line is led back to the cockpit, and all seems in good working order. However, the friction in the overall system means I have to coax the rear down from the end of the boom, and then "reef" it in from the cabin top pretty vigorously to get a decent result, and this is pretty unacceptable from a "when you really need it" standpoint.
I seem to recall reading somewhere about adding blocks to the reef cringles to reduce friction. This makes sense, but I am unclear as to how to do this. Anyone have any ideas that don't require a sailmaker? How about pictures?
Thanks!
Jon Freeman
C-310 "Summer Sojourn"
Seattle (Tacoma) Washington
Tim -
Thanks for the idea. This is perfect!
BTW - You and I have a mutual friend at Boeing, also named Tim (O.). When I bought my 350 three years ago, he mentioned sailing on yours.
I'll set this up, and let you know how it works, but I can tell it will be great. Meanwhile, I'll look for you on the Sound.
Thanks again!
Jon Freeman
Seattle/Tacoma
Sep 29, 2008
1,980
Catalina 310 #185 Quantico
Tim, That is wicked sweet!
Kind of stuff I would expect from Paul J. I am pretty excited and appreciate you posting that as I have used my reefing system only a few times and noticed that the system was a little sub-par. Your solution is really simple and I will probably do that this weekend. Thanks for posting!
Tim (and all) -
I installed Harken 40mm Carbo blocks with rings, as shown on Tim's link. This works GREAT! Reefing is smooth and slick, with no hangups. The clew comes down to the boom as sweet as can be, and the reefing maneuver is exactly as one could hope for.
Excellent, and recommended mod!
Jon Freeman
Seattle/Tacoma
Dec 2, 2003
392
Catalina 350 Seattle
Jon - glad that worked out for you. It took me a few minutes to remember, but yes, TimO had mentioned being on your boat. I'll mention to him that you mentioned him....
Tim Brogan
April IV C350 #68
Seattle
