Wire/Rope Halyards
Hermit,
Just a question....if you have wire/rope halyards now, why are you changing them to all rope (with the added expense)? Why not use the ones you have now? I suspect that the existing ones may be old, dirty, even green in color (if they are like the ones I used for 22 yrs. on my previous boat). But that doesn't mean that they won't work. I've noticed on lots of threads on a number of different forums, that when people purchase an older boat, especially those that fit into the project category (and I'm not sure yours does), that one of the first things they do is to spend lots of money on new standing rigging (wire shouds and stays) and all the running rigging (halyards, sheets). In most cases, I doubt that these owners even have a clue as to whether these need to be replaced....sure, nice new shiney stainless steel rigging and good clean, and probably color coded sheets are nice, but they cost lots of money. If one has the money to spend, fine, but if one is, at the time, constrained by a tight budget, why not use the old ones until money becomes more available. Also, I curious as to where the original jib lead blocks are...it seems odd that you have a boat without these (unless some previous owner, like the second owner of my old boat did, decided that these were not really needed and did away with them)? After I sold my old boat (a 28 ft. Kells), the next owner used it for 3 years with the same halyards and sheets (except he did add a roller furler for jib and associated equipment to that). Those dirty old halyards and sheets worked fine, looked like heck, but worked fine. Also, I never recognized any problems with the wire/rope halyards..they worked fine. The next (third) owner, was going to upgrade the boat...true to form, the first thing he did was to replace all the halyards with pretty new all rope halyards. Next, he decided that he really didn't need the jib block cars and the associated tracks...then there was lots more, took off the rudder for some reason (it worked fine), but he did lots of sanding, grinding and such. But he never, ever took the boat sailing and it lies abandoned in one of the local yards. If you can, use the old gear until you can replace it. Good luck and hope you get to sail soon. Also, either mainsail only or jib only will, in my opinion, keep things tamer until you and wife are comfortable with sailing. Then add the second sail.
