I have thought about a loose footed main, but I am going to order one with a shelf ( my sail now has one) and a bolt rope or slugs. My feeling is a main with slugs ( on the foot) will be easier to adjust, over one with a bolt rope. I can see there are many different opions on this. I have not heard a good reason not to order the slugs. It could be just a matter of what you feel will work for you. It sure makes a good thread.
Dale
You cant have slugs without a boltrope and expect a sail to have long life. Boltropes are installed so that the sail doesnt stretch completely out of shape at the designed wind strength ... usually 15+ knots. Slugs are installed through grommets that are adjacent to a boltrope .... so that the slug attachment points dont easily pull out of the sail material ... Boltrope AND slugs.
Sails without boltropes are easier/faster/cheaper to construct; using heavy sail 'tape' in lieu of the boltrope; but, the tape isnt as strong nor as 'elastic' as a boltrope and if you sail in wind conditions above the 'tape' luff/foot will ultimate wind up with a grossly and permanently 'stretched out of shape' sail.
Loose footed mainsails typically use a boltrope on the luff and a taped foot; but, since one doesnt usually 'stretch out the foot' (in comparison to the needed stretch in the luff), a taped foot works well and lasts long on a 'loose footed' mainsail. Loose footed (taped foot) is vastlly better for control of the 'amount of draft' in a sail. Aerodynamically there is no advantage for a shelf footed mainsail.... because the loose footed sail usually has an 'apron' that hangs down below the boom (tack—clew line) to 'compensate'. the loose footed sail is the prime choice if you want any 'adjustability' in the amount of draft in a mainsail. Boltroped foot mainsails are an obsolete design.
Of course if you dont 'shape' your sails (by correct halyard/outhaul, etc. tensions) after you raise them, all the above wont matter. ;-)
